Author Topic: NT Danmark  (Read 49910 times)
Capernaum
NT Danmark
« on: June 09, 2012, 01:03:22 am »
Season 7 - National Team
I'm looking forward to this season. My first season as commander in chief of the best danes.
We are going through 10 races this season with many mountains - where we have a few very good riders, so that's good.
I was wondering, where I find the percentages you have been using for the other seasons for the updates ? Do any have an excel file where all categories you use are ready to be used - so i can copy/paste riders in ?
« Last Edit: August 18, 2012, 03:39:31 pm by SCyclingUSA »
Kazistuta
  • Team_Boogie_Woogie
Re: S7 - NT
« Reply #1 on: June 09, 2012, 03:38:07 am »
The Danish climbers are not good enough to score points in the pure mountain stages, but Max Nordby should have a chance to do well in the overall (3 races for him perhaps).
Nevertheless, here do you find the percentages used:
http://85.52.224.56/smf/index.php/topic,344.msg21951.html#msg21951
(remember, these are general values, not stage specific)
Capernaum
Re: S7 - NT
« Reply #2 on: June 09, 2012, 02:15:39 pm »
Thanks, it was also just the percentages for the gv lists i was looking for.
Re: S7 - NT
« Reply #3 on: June 09, 2012, 03:13:24 pm »
Autosortering af rytter GV.
Der er plads til omkring 100 ryttere og GV kan ændres til det ønskede. De GV der benyttes til opdatering af danske ryttere kan ændres til default eller man kan benytte sig af sine egne.
http://www.2shared.com/document/jK0OXqnm/NT_ALL.html
Use the link and download exactly what you are looking for!
It will sort the rider with the best GV..
Copy past rider skills from A2:M102
Rider autosort will be shown in R104:W130 (Name, Age, GV percentages, Team, ændring = change(you need to manual insert GV from last season to see the change)) Dont mind the other columns to the right from ændring/change!!  :P
Change the GV in X2:AI2 (Copy paste the percentages from the below list)
Capernaum
Re: S7 - NT
« Reply #4 on: June 09, 2012, 03:43:18 pm »
thanks, i saw your link in another thread and downloaded, just finished the lists now...so easy with your tool :)
Capernaum
Re: S7 - NT
« Reply #5 on: June 09, 2012, 04:51:09 pm »
Race 1 June 10 - 2012
Nicky H.Rasmussen   ADBV   25   72,81
Johan Benson   Bazen   24   69,93
Max Nordby   ANGELESLAKERS   24    77,91
Bjarne Poulsgaard   senses   23   70,10
Felix Pless   TeamSolex   23   72,32
Fillip Kirstejn   Teamsystem   23   70,62
Nickolai Kragh   barakaldo   23   68,90
Magnus Lamp   Team_Boogie_Woogie   22   69,50
Oskar Krøjgaard   Team_Boogie_Woogie   22   69,42
Going all in on Nordby, and hopefully Nicky is good enough to be around top 20.
Re: S7 - NT
« Reply #6 on: June 10, 2012, 02:26:08 pm »
We have tried with a free role to Nicky several times. I dont think the 2 flat sections in the start of the race will change anything. It is a advantage for Max.
Nicky usually end up at the 40 - 50.
Capernaum
Re: S7 - NT
« Reply #7 on: June 10, 2012, 10:51:57 pm »
Max had 8 helpers, but it didn't really work out as I had hoped. Max ended 12th. My guess is that it's not as good as expected :(
12    Max Nordby      24   a hours 0 minutes 9 seconds    100      ANGELESLAKERS
60    Fillip Kirstejn      23   a hours 0 minutes 38 seconds    0      Teamsystem
76    Johan Benson      24   a hours 0 minutes 49 seconds    0      Bazen
90    Nicky H.Rasmussen      25   a hours 0 minutes 55 seconds    0      ADBV
97    Valdemar Lambæk      22   a hours 0 minutes 58 seconds    0      IKIBASQUE
100    Bjarne Poulsgaard      23   a hours 0 minutes 58 seconds    0      senses
138    Felix Pless      23   a hours 1 minutes 16 seconds    0      TeamSolex
152    Oskar Krøjgaard      22   a hours 1 minutes 28 seconds    0      Team_Boogie_Woogie
153    Magnus Lamp      22   a hours 1 minutes 28 seconds    0      Team_Boogie_Woogie
Sorry about the result. Lets hope I can do better in next race. Hills and mountains.
Kazistuta
Re: S7 - NT
« Reply #8 on: June 11, 2012, 06:37:45 am »
No harm done  :)
Can we hear the tactics of the various riders? Was i bit surprised to see Krøjgaard get left behind at first section, because his flat is better than Lamps.
Re: S7 - NT
« Reply #9 on: June 11, 2012, 01:54:56 pm »
If you compare this result with the 1st stage from last season. You will be suprised. The 2 flat sections in the start have some sort of impact.
Capernaum
Re: S7 - NT
« Reply #10 on: June 11, 2012, 03:48:04 pm »
Nicki H.Rasmussen : 1-1-4-4-2
Max Nordby : 0-0-4-4-4
Bjarne Poulsgaard : 2-1-4-4-1
Nckolai Kragh : 2-1-4-4-1
Johan Benson : 2-2-5-3-0 (Benson did good as a helper, was not expecting it would be him that helped Max)
Fillip Kirstejn : 2-2-5-3-0
Felix Pless : 1-1-5-4-1
Magnus Lamp : 2-2-4-4-2
Oscar Krojgaard : 1-2-5-4-0
I was expecting many of the riders with Max on the two flat, so they could go "crazy" on the hills and support him on section 3 and 4, but it didnt work, because many was already gone on the two first sections.
Capernaum
Re: S7 - NT
« Reply #11 on: June 13, 2012, 08:35:34 pm »
race 2
Kent Fjordblink   25   76,46CandasuTeam
Aleksander Sinkbæk (weather)22   75,12loshipoglucidos
Nicholai Thorsbjerg2571,57skunk
Jimm Nørskov25   72,85sNoW4PeTiNikeiS
Christian Næsvang (weather)2372,36Hyperorbitals
John-Erik Nymark23   68,42SparCanToTe
Håkon Sandholm   2368,55TeamSolex
Lauge Herner21   66,95Palmeiras_Marcos
Who should it be ?XX   XX,XXXXXXXXXX
Difficult race to make percentages for. I tried my best. I would really appreciate, if you have experience with other percentages for this race.
Stamina: 18
Climbing: 40
Technique: 9
Downhill: 20
Hills: 9
Team work: 4
« Last Edit: June 14, 2012, 05:25:00 pm by Capernaum »
Kazistuta
Re: S7 - NT
« Reply #12 on: June 13, 2012, 09:52:07 pm »
Obviously you should decide for yourself which riders to select, but neither Thorsbjerg, Nørskov or Fjordblink will ever be able to get points in these races on NT. They are simply racing too much and are too versatile to be really competitive in these races on national team level. Just look at the results from the last seasons.
I would select Max Nordby, even though he is not great suited for this race, he still has enough upside (and as far as I know is still training climbing to become a star hill-climb rider), and use the three "old-timers" spots on some of the promising young riders. That's my opinion, I understand that you want to try and compete with the best team possible, but I just wanted to give you a heads up to not expect miracles from the trio. Sinkbæk and Herner looks extremely promising though.
ProSCycling
  • Pro-SCycling Cannondale | U21-DENMARK
    • SCyclingUSA website
Re: S7 - NT
« Reply #13 on: June 14, 2012, 12:07:55 am »
As I remember it, Sinkbæk has low hills skill, so it's crazy to see how good his GV is in this race. He will be amazing in the pure mountains.
Good luck with the race. I have had some success in a race like this before, so I can give you some tips for the tactics  :P
Re: S7 - NT
« Reply #14 on: June 14, 2012, 05:02:31 pm »
I Think stamina is more and hill is less.
I Think you Can find riders who are just as good as thorsberg and nørskov or sandholm. These riders are Tour riders and get Lots of Exp. Hans-Kurt kølle-Jørgensen should be ok in a race Like this.
The renson i tell you this. there is no Way you Can get points in a race Like this. Thats why i go with kazi s suggestion. But you are welcome to try  :P
« Last Edit: June 14, 2012, 05:11:05 pm by TeamSolex »
